linux Moho minimize issue
rylleman
Post by rylleman »
If I minimize the main Moho window to the panel-bar I can't open it again, not with unminimize and not with maximize. I have to close the application and start it again.
Installed Moho 5.4 on my Ubuntu 6.10 machine.
Yes I have same problem. With Moho and also with AS pro beta version. You can avoid it by pressing the ALT + TAB keys until the main window is selected, then raise the keys and the main window will be resotred again. You don't need to start the application again (you could loose the not saved work).
Cheers
rylleman
Post by rylleman »
Ah, thank you!
