Shoulder Probelms
Andrell
Shoulder Probelms
Post by Andrell »
Ok so i have a bone for a vector image i have created in AS, i split it up and done all the procedures properly but i am having probelm with the shoulder i don't now how to set up the bone to create shoulder movement.
Patmals
Post by Patmals »
The shoulder would work as part as the upper arm. so the bone. so the its part of the upper arm bone.
I think.
Maybe you should show how you have rigged this.
The bone masters will give you better help if needed. :)
Read this.
Anyway you can solve it easily if you connect the lower line of the arm to the body lines. Don't worry about frame 0 (where every thing should be splitted apart) At frame 1 all the lines go to the desired position.
