Remove all animation except one frame?
bearc0025
Post by bearc0025 »
I want a second scene to start where the last scene left off. I copy the anme file and can copy the last key frame to frame 1, but the rest of the animation is still in the timeline.
Maybe a script to save an entire key frame set to a file and load? Remove all animation after/except this key frame? Other?
Thanks in advance!
What I've tried...
I tried doubling the length of the time line and copying the (new) second half over the first, but that just copies key frames and doesn't remove existing ones.
I don't want to start the timeline of the new scene at last frame of the previous scene b/c a) that throws off the audio and b) the farther out your start your first frame, the longer the rendering takes (I learned from experience).
The only solution I think I've thought of is to copy the last frame to frame 1 and then go thru all my layers, select all key frames, de-select keys at frame 1 w/ shift-click and delete. Yow!
[url=http:///www.thebooples.com/]Booples[/url] - Children's Bible song DVD
IndieAnim - independent animation forum
