Gradient to transparent
Guto
Post by Guto »
Hi everyone,
As far as I understand, is impossible to draw something in gradient to transparent in AS.
Is it right?
If you want a gradient to transparent it is not possible in AS. It is possible to have "halo only" or "shaded only", that could be similar in some aspects.
See this thread.
Guto
Post by Guto »
Thanks Genete.
That is what i thought... Too bad :cry:
DK
Post by DK »
You could possibly draw your transparent object with gradient in Photoshop, save as a .png and import it into AS. The .png will maintain it's transparency in AS.
D.K
cribble
Post by cribble »
Only problem then is that if you zoom in, it'll pixallatte, and if you make it big enough to handle zooms, the Flash export will hate it. Guess it depends on what you're doing.
--Scott
cribble.net
Guto
Post by Guto »
Yeah...
The problem gets hard if you want to work with a flashlite that distorts as long as it iluminates the ambient.
Not can do with AS and neither with PNG.
cribble
Post by cribble »
Just use Flash. Surely you could dub in the same results in Flash after using AS to animate with.
--Scott
cribble.net
Guto
Post by Guto »
cribble wrote:Just use Flash. Surely you could dub in the same results in Flash after using AS to animate with.
Yes cribble,
That's exactly what i did. Thanks man
