Menus in MOHO 5
Menus in MOHO 5
I am a little uneasy with the use of pointer in MOHO5. It takes longer time to change my pointer without any shortcut. May be this problem has already been resolved in Anime STudio but I haven't purchased it yet.
ARIEF DERMAWAN
Hello Aswa (Arief ?),
Sorry, I do not understand your question - possibly a translation problem.
Pointer? Menu?
Do you mean:
- adding or moving points?
- converting between smooth and peaked (pointed)?
- something else?
Can you show us an example of what you mean?
Regards, Myles.
Pointer? Menu?
Do you mean:
- something else?
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
Are you talking about the mouse pointer, also sometimes called the "mouse cursor"?
It's possible to change keyboard shortcuts in Moho or Anime Studio Pro*, but it's not easy, and there are few choices available for keyboard shortcuts. I'll put up a link to a forum thread about that if you like. I learned how to do it, but it is difficult and doesn't give me many useful shortcut keys that I would prefer.
*maybe it's possible in Anime Studio [not Pro], but I don't know. I have Pro.
MacBook Pro 17", 2.16Ghz, 2GB RAM, 5400rpm 120GB HD
ASP 5.5 updated August 2007
OSX 10.4.9
OSX 10.4.9
Default keyboard shortcuts in Moho 5.4 and Anime Studio Pro 5.5:
Regards, Myles.
Moho 5 shortcut keys.
See also the non-alphabetical shortcuts listed in the Moho helpfile.
A : add point/bone Ctrl-A : select all
B : select bone Ctrl-B : Batch export
C : adjust curvature Ctrl-C : copy
D : delete edges Ctrl-D : random line thickness
E : rectangle Ctrl-E : export animation
F : freehand drawing Ctrl-F : toggle NTSC safe zone display
G : group (select) points Ctrl-G : snap to grid
H : hide edge Ctrl-H : toggle output only
I : bind points Ctrl-I : select inverse
J : Ctrl-J :
K : Ctrl-K : actions window
L : oval (ellipse) Ctrl-L : reset line thickness
M : smooth Ctrl-M : mute soundtrack
N : noise distortion Ctrl-N : new document
O : Ctrl-O : open document
P : re-parent bone / peak point Ctrl-P : preview render
Q : select shape Ctrl-Q : quit
R : rotate points/bone Ctrl-R : render
S : scale points/bone Ctrl-S : save document
T : translate points/bone Ctrl-T : insert text
U : create shape Ctrl-U : show tracing image
V : Ctrl-V : paste
W : line width Ctrl-W : close document
X : magnet Ctrl-X : cut
Y : Ctrl-Y : select tracing image
Z : manipulate bones Ctrl-Z : undo
0 : set origin Enter/Return : select none
1 : translate layer Tab : select connected
2 : scale layer
3 : rotate layer
4 : track camera
5 : zoom camera
6 : roll camera
7 : pan/tilt camera
8 : rotate workspace (also Ctrl-RMB)
9 : orbit workspace
Right-mouse : pan workspace, drag numeric fields
Shift-Right-mouse : zoom workspace
Ctrl-Right-mouse : rotate workspace
Mouse wheel - scroll timeline, zoom workspace
- numeric fields (Ctrl to halve, Shift to double)
Ctrl-[ : Timeline window
Ctrl-] : Style window
From the Moho manual:
Alt+Backspace, Alt+C, Alt+V - delete, copy, paste keyframes
Can be used any time
Escape Automatically adjust the view to see
everything in the active layer
- hold the shift key to zoom in on the
currently selected points
Home Reset the view to see the overall project
Enter/Return De-select all points
Tab Select all points that are connected to
the current selection
Left Arrow Step back one frame in the timeline
- hold shift to rewind
Right Arrow Step forward one frame in the timeline
- hold shift to advance to end of animation
Working with a Vector layer
Delete/Backspace Delete the currently selected points
Spacebar Weld two points together - usually used with
the Translate or Add Point tools
Working with Fill tools
Delete/Backspace Delete the selected shape
Spacebar Define a shape based on current selection
Up Arrow Raise selected shape up one level
- hold shift to raise to top
Down Arrow Lower selected shape down one level
- hold shift to lower to bottom
Working with Bone tools
Delete/Backspace Delete the selected bone
(and any child bones)
Spacebar Bind points to selected bone
Up Arrow Select parent of current bone
Down Arrow Select child of current bone (only works if
current bone has just one child)
Working with the Timeline window
Alt+Backspace Delete the selected keyframe(s)
Alt+C Copy the selected keyframe(s)
Alt+V Paste the previously copied keyframe(s)
Spacebar Play/stop animation
Page Up When in graph mode, zoom in on the timeline
- hold shift to move the graph up
Page Down When in graph mode, zoom out from the
timeline - hold shift to move the graph down
End Auto-zoom the timeline, based on the active
animation channel (when in graph mode)
-- Groucho Marx
-- Groucho Marx
That's what I mean ! Thanks a lot
You're so helpfull Sir/ Madam
.. yeach, I don't really know about technical terminologies, even though I use MOHO 5 for my works..
Btw, I am writing a book about film production from pre to post and including 2D animation. the book would be published by one national publisher in Indonesia (I got the contract) and I want to promote MOHO 5 and Anime Studio there. It's because the program is really powerfull! and easy!!!! and I make animation in only 1 hr!
Do you have any suggestion what features shall I include so that it won't give bad effect to MOHO and AS?
The animation would be combined with real/ live shot and 3D animation depending on the 10-minute script.
Thank you for the helps, I luv you all guys...
ARIEF DERMAWAN
- toonertime
shortcuts
it was nice to see the keyboard controls
all laid out like that
is there any way to print it out from here?
Re: shortcuts
Try dragging to select it then copying and pasting it into a word processor or text editor to print it.toonertime wrote:is there any way to print it out from here?
Note: use of a proportional font will probably result in misalignment. A monospaced font such as Courier will be more aligned (but may look uglier).
If copy and past doesn't work, let me know and I'll upload the text file somewhere.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
Re: That's what I mean ! Thanks a lot
The "really powerfull! and easy!!" part is a good start.Aswa wrote:I am writing a book about film production from pre to post and including 2D animation. [...]I want to promote MOHO 5 and Anime Studio there. It's because the program is really powerfull! and easy!!!! and I make animation in only 1 hr!![]()
My opinions, worth what you paid for them
I would concentrate on bones (easy and advanced rigging, and bone constraints), switch layers (for eyes, hands, mouths, etc), and point animation for particular tasks, and also mention Papagayo, a freeware add-on for creating good lipsynch.
Bones are probably the best animation feature, and the fact that Anime Studio is so clearly focused on character animation.
For the Pro version: scripting, particles, actions, variable line width, and 3D layer placement and 3D camera movement are the best features in my opinion.
Even the Pro version compares very well in price to other 2D animation software.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
Re: shortcuts
I had to do that for myself yesterday, so I might as well share the PDF I made:toonertime wrote:is there any way to print it out from here?
http://mooncaine.net/images/moho-asp/Mo ... rtcuts.pdf
Download it and keep it because I might not leave that file up permanently, OK? BTW, the fonts are big because I use huge monitors.
OSX 10.4.9
OSX 10.4.9
