export error
pyromanizak
export error
Post by pyromanizak »
hi, wen eva i export any animation in a format other than avi i just get a grey screen but i tried wit that winsor guy and only his hair and part of his eye exported properly. any1 no wots wrong
pyromanizak
sorry i just realized i should of put it under the bugs forum
Well, before it goes in the "Bugs" section, you may consider trying the "How Do I" section first...you need to find out if you are doing something wrong before you decide there is a bug in the program.
pyromanizak
i hav tried changing all the settings and with different animations
It sounds like it might be the "other format" that is causing the trouble. What other formats are you trying to export to?
SWF will not export certain things, like distorted image layers for example. I believe the Winsor file has some flexible bone distortion on some of the image layers. This would mean those layers won't export.
All of the other "formats" are raster formats and shouldn't cause any trouble. If you are only talking about SWF then that makes sense. I just did a test and the winsor file does NOT export to SWF properly. I get just a head and hair because those other image layers are not optimized for SWF output.
