Pen and paper characters...
CrAzY Dan
Post by CrAzY Dan »
I have drawn a knight on paper and i have scanned it in and cut it out in MS paint into seperate layer parts.
When i imported the seperate parts into Moho, there are squares of white surrounding each image.
How can i stop this from happening?
Thanx
CrAzY Dan :?
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
bupaje
Post by bupaje »
I'm not sure that you can do it in MS paint. You need to be able to cut it out, then save it as a PNG with the areas outside the body defined as transparent. If you don't have other software you may look into GIMP and ask someone here how to save your image as a PNG with transparency in that program.
jorgy
Post by jorgy »
Yeah, if you use gimp, I can help you with using it to save as PNG with transparency.
CrAzY Dan
Post by CrAzY Dan »
Okay then Thanx.
How do i do it? I have got Gimp now.
Thanx again :lol:
jorgy
Post by jorgy »
Here is what I would do:
Using the magic wand tool (Z), select the area outside of your cartoon. It should select all of the white areas. Then, invert the selection, to choose your cartoon (control-I). Copy this to the clipboard (control-C). Create a new canvas (control-N). Make sure that this has transparency/alpha enabled!! This is the secret. Then, in the new canvas, paste in your cartoon (control-V). You should see your cartoon in the middle, with a checkerboard around it, indicating the transparent sections. Save this file as a PNG file, and it will import into moho without your border.
Let me know if you need more detail on this.
jorgy
Nichod
Post by Nichod »
Personally I'd use a simple prog called photofiltre. It have a function that makes a specific color transparent.
Sometimes in order to accomplish something you need to not sleep.
CrAzY Dan
Post by CrAzY Dan »
How do i check if i have transparency/alpha channels enabled?
jorgy
Post by jorgy »
When you create your new image, click on "advanced" and then there is a label "Fill with". Make sure that this says "transparency". Hope this helps.
CrAzY Dan
Post by CrAzY Dan »
Thanx alot, Jorgy! :)
mr. blaaa
Post by mr. blaaa »
yes.
best would be paint shop (alpha channel). but u can download GIMP for free and keep it running for free. it has all basic features paintshop has.
thanks to the GNU-License u dont need to spend a lot of money to slove your alpha-channel-problem.
