I have drawn a knight on paper and i have scanned it in and cut it out in MS paint into seperate layer parts.
When i imported the seperate parts into Moho, there are squares of white surrounding each image.
How can i stop this from happening?
Thanx
CrAzY Dan
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
I'm not sure that you can do it in MS paint. You need to be able to cut it out, then save it as a PNG with the areas outside the body defined as transparent. If you don't have other software you may look into GIMP and ask someone here how to save your image as a PNG with transparency in that program.
Using the magic wand tool (Z), select the area outside of your cartoon. It should select all of the white areas. Then, invert the selection, to choose your cartoon (control-I). Copy this to the clipboard (control-C). Create a new canvas (control-N). Make sure that this has transparency/alpha enabled!! This is the secret. Then, in the new canvas, paste in your cartoon (control-V). You should see your cartoon in the middle, with a checkerboard around it, indicating the transparent sections. Save this file as a PNG file, and it will import into moho without your border.
