library character lip syncing
The walk cycle is 31 frames long so your action needs to take place after it not during it. So in your example, hold still till 354, then walk till 385, then on frame 386 you put your trip action. Here's an example file, right click and choose save as.
http://dl.dropbox.com/u/53649091/walkandtrip.anme
no, the file you sent shows what you were trying to show, but the file I've created thus far, which has a background image, 4 characters and 2 audio files, only shows the audio file on the channels tab, on the squencer tab I see everything, but not on the channel tab - difference between pro and debut?
No I made that file in Debut, but here's a step by step video. If this doesn't give you a clue to what's wrong then you can upload the anime file to a file sharing site like Mediafire( its free) and I'll try to see whats wrong.
http://dl.dropbox.com/u/53649091/waltripper.wmv
You are absolutely right! I was adjusting the switch layer not the bone layer! I also think I've probably messed this thing up so much at this point I'll be better off starting from scratch to avoid any glitches in it, I have to run out for awhile, I need to go take care of my father, getting his dinner on and trash out for pickup, then I'll rebuild, so hopefully the only other thing you'll hear from me is a final "DONE! THANK YOU!" but it might not be till late, so I'll say thank you again, and when (and if) I actually accomplish this, I'll post on youtube and send you a link. YOu have been so patient and fantastic in helping me, I can't thank you enough.
I got it done, thank you so much for the help, I couldn't have done it without you!
http://www.youtube.com/watch?v=f6UnV_FORqQ
