New Animated Skit
Yosemite Sam
New Animated Skit
Post by Yosemite Sam »
Hello fellow humans.
Here's what I've been working on lately. It has a few F-words. But otherwise is pretty safe.
I'm not completely happy with it, but there's always next time...
Jimmy Mills
Some of my Moho Pro work.
Danimal
Re: New Animated Skit
Post by Danimal »
This was beautifully animated and the caricatures were very good. However, for all of the interview, the two funniest things I found were the opening theme and the Larry Merchant boxing poster in the background. And when Larry merchant said he wanted to discuss one event, I thought for sure he was going to cite some obscure punch from one round of one fight, as he always does: "what were you thinking in round 4 when you took that jab to the right cheek?"
Anyway, great video!
~Danimal
Yosemite Sam
Danimal wrote:This was beautifully animated and the caricatures were very good. However, for all of the interview, the two funniest things I found were the opening theme and the Larry Merchant boxing poster in the background. And when Larry merchant said he wanted to discuss one event, I thought for sure he was going to cite some obscure punch from one round of one fight, as he always does: "what were you thinking in round 4 when you took that jab to the right cheek?"
Haha, thanks, and you are definitely a boxing fan if you know that.
And yes, I almost didn't post this because I just felt that it wasn't very good (the joke). I was talked into posting it :)
I learned a valuable lesson that I already knew: You can't polish a turd.
But.... you live and learn.
Jimmy Mills
3deeguy
Post by 3deeguy »
This clip could get a lot of views. I remember selgin's animation of the Beatles crossing Abbey RD which went viral. I'll favorite this one in YT and watch its activity.
Cheers, Larry
sargumphigaus
Post by sargumphigaus »
I really like how you handled the hands in this. The transitions are seamless. I may have to take a leaf out of your book. I need to follow your example with my current project, as i'm going to use convoluted movements, and hands are the most intimidating factor for me.
Little Yamori
Post by Little Yamori »
Your caricatures are awesome, and your timing with edits and scenes really make it flow (the only scene that went by a bit too quick was the image of the chocolate ears, I had to run it back a couple of times to read what it said). If Tyson's voice was a just little higher pitched and lispy it would have been closer, but I thought the whole chocolate thing was pretty funny, you just may have stumbled upon the real reason for the bite.
[quoteI learned a valuable lesson that I already knew: You can't polish a turd. ][/quote]
I wish my turd projects were this polished :D
3deeguy
Post by 3deeguy »
I'm still trying to master the hair 'fade'! I remember you described it for me but it's still a mystery. A 'soft edge' fill is the closest I can get. I've had problems animating gradients so I prefer soft edges. Characters with blowing hair and clothes don't impress me. With my current character I want to 'fade' the eyelid as opposed to an outline. We might need you to do a tutorial on your technique!
Cheers, Larry
Yosemite Sam
sargumphigaus wrote:I really like how you handled the hands in this. The transitions are seamless. I may have to take a leaf out of your book. I need to follow your example with my current project, as i'm going to use convoluted movements, and hands are the most intimidating factor for me.
Thanks. It's really just trial and error with the switch layers. You have to find that sweet spot to make the transition, so it flows and isn't jarring. Its tougher during slower movements.
Jimmy Mills
Yosemite Sam
Little Yamori wrote:Your caricatures are awesome, and your timing with edits and scenes really make it flow (the only scene that went by a bit too quick was the image of the chocolate ears, I had to run it back a couple of times to read what it said). If Tyson's voice was a just little higher pitched and lispy it would have been closer, but I thought the whole chocolate thing was pretty funny, you just may have stumbled upon the real reason for the bite.
Thanks. I considered doing the Tyson voice higher, and maybe should have, but his current voice isn't as high as it once was. Still, maybe I should aim less for realism/accuracy with my voices and more for exaggeration -- like my caricatures drawings. Something to consider.
Jimmy Mills
Yosemite Sam
3deeguy wrote:I'm still trying to master the hair 'fade'! I remember you described it for me but it's still a mystery. A 'soft edge' fill is the closest I can get. I've had problems animating gradients so I prefer soft edges. Characters with blowing hair and clothes don't impress me. With my current character I want to 'fade' the eyelid as opposed to an outline. We might need you to do a tutorial on your technique!
Yes, I can do a tutorial for sure. Guess I'm not quite sure what you are having issue with. Tyson's hair fade?
Jimmy Mills
3deeguy
Post by 3deeguy »
Yes, Tyson's hair fade.I also want to use a fade technique around the eyes, like mascara. If there's a way to bind a gradient to a bone I never learned it.
Cheers, Larry
Yosemite Sam
3deeguy wrote:Yes, Tyson's hair fade.I also want to use a fade technique around the eyes, like mascara. If there's a way to bind a gradient to a bone I never learned it.
Sorry for the late reply. That's a mystery to me as well. You'll notice with Tyson's fade for example, there's not a lot of drastic movement with it. So you can't tell. But when I did the Lebron skit, you could really notice that the gradient wasn't bound to the bones of the 'Hat' characters' eye shadow make-up.
If anyone out there has any ideas or work-arounds on this, please share. Otherwise, this will be something I will definitely add to the list of feature requests for future versions of AS.
Jimmy Mills
nwboy74
Post by nwboy74 »
I want to have your babies.
Hentron
Post by Hentron »
I liked the over the top blood splatter from the Indigenous American's arrow.
Pinesal
Post by Pinesal »
This was some pro quality stuff.
How did you make the drop shadow show on the back of the chairs but not anywhere else, like the wall behind it?
