Need to Animate Edges (chainsaw)
Does anyone have any ideas regarding animating the outline shape of an object? For example, I would like the teeth of this blade to rotate around the blade.
Re: Need to Animate Edges (chainsaw)
Maybe a fast looping 3 frame cycle?
My opinions and comments do not represent those of my employer.
http://www.ernestpchan.com
I know that FBF is a choice, I was just hoping someone had an easier method.
You can animate and cycle the curve profile to do this.
I was thinking the same thing. I originally tried to animate a curve profile, but kept getting sub-par results. Basically, as I animated the source curve, the main curve would have unwanted distortions. For example, the curve would wobble as it's source is distorted.synthsin75 wrote:You can animate and cycle the curve profile to do this.
I decided to combine the idea of animating a curve profile with FBF. In order to do this, I made reference layers to the chain layer in a switch and gave each reference a slightly offset curve profile. It worked really well!
File Download: https://drive.google.com/file/d/0Bwzk-f ... sp=sharing
I used the same technique to create one of the Amoeba Boys from the Power Puff Girls.
This may be a bit simpler.
https://sites.google.com/site/synthsin/ ... ects=0&d=1
Can you get this to work for a waveform? When I tried, I get the distortion that I talked about earlier.synthsin75 wrote:This may be a bit simpler.
Waveform is the same idea, but probably won't look as smooth, especially the slower you run the cycle. In that case, your FBF method may be better.
