With Actions, is there a way to keep a bone's rotation between 0° and 360°?
drumlug13
Post by drumlug13 »
Is there a way to create Actions and keep a bone's rotation between 0° and 360°?
I guess the best example would be to think of it like a clock that you can continue to wind starting at 0° but instead of the bone's rotation going above 361° when it comes back around (where it loses it's connection with the Action), is there a way to make it automatically reset to 0°
I don't know if I'm explaining it clearly, but I have an object turning 360° in 3D space and right now I have to keep resetting the bone's action when it comes around to the starting position. I can't find anything in the menus but an internet AI search says Moho has something called "Angle limits → Use circular angle constraint" but I can't find those settings anywhere.
Adam
Re: With Actions, is there a way to keep a bone's rotation between 0° and 360°?
In Moho 14.4, if you have a smart bone that rotates exactly 360 degrees, it will automatically repeat the same animation every time you rotate the smart bone past multiples of 360 degrees.
drumlug13
Post by drumlug13 »
Well.... that is some incredibly amazing timing... It works perfectly outta the box ...
Of course now I'll spend the rest of the day wondering what would have happened if I would have wished for a winning lottery ticket instead
As usual... Thanks again Wes.
Adam
drumlug13
Post by drumlug13 »
HUGE time saver. Here's a rig I'm working on now, the smart bone is turning the back of the UFO cockpit dome 360°. The idea is that the alien will be able to change the UFO's direction just by leaning that way... Probably my favorite update since the smart bones
Adam
