How do I easily cut a clear hole in an object?
DVTVFilm
Post by DVTVFilm »
You're describing a Boolean operation. There are no Boolean operations in AS -- it's a (mostly) two-dimensional animation program...
DVTVFilm
Post by DVTVFilm »
okay--thanks...
Trondheimfan
Post by Trondheimfan »
Remove the color from both objects, using the "delete shape"-tool (in the box's case, just from the light purple part). Now select both the square and the circle.
When you select the "create shape"-tool, you should already see that Moho treats the circle as a hole in the object. Just add the desired color, and there ya go.
DVTVFilm
Post by DVTVFilm »
Perfect--thanks...
