Smooth Head and Body Turns
- superanimatrix
Hi guys, How do I get those smooth head turns and body turns?
You animate them by hand. The more drawings, the smoother the movement will be. You could either pre-fabricate the phases of a head turn and put them into a switch layer, or you could do a frame-by-frame point aninmation, or you spend some time to build a rig as described elsewhere which could do a decent smooth head turn in a limited range but will only work for certain styles.
- superanimatrix
I have not learned what a switch layer is yet. I'm just starting out!slowtiger wrote:You animate them by hand. The more drawings, the smoother the movement will be. You could either pre-fabricate the phases of a head turn and put them into a switch layer, or you could do a frame-by-frame point aninmation, or you spend some time to build a rig as described elsewhere which could do a decent smooth head turn in a limited range but will only work for certain styles.
- superanimatrix
Do you have the links to those? or did you already give em to me?Genete wrote:For head turns also watch DarthFurby's video tutorials. There are tree videos and uses actions to perform head turn. (Tips and Techniques sub forum).
Also don't loose ***Resources*** sticky post in same sub forum. Lots of interesting threads there.
viewtopic.php?t=8301
viewtopic.php?t=8525
viewtopic.php?t=8867
And ***Resources*** is a sticky thread at the beginning of Tips & Techniques sub forum.
Now you have a LOT to watch and read.
- superanimatrix
Are you having any problems with the links to the lessons? When I click those links to the lessons the pages are blank!Genete wrote:viewtopic.php?t=8301
- superanimatrix
Ok, I will do that. Maybe the video is taing a while to download. I have another question, I am woring on my first character (The Greek One) I made is head too big and need to make it smaller so I can draw in the torso, how do I do this? Also can I make the stage bigger?Genete wrote:No. For me the links work perfectly.
Anyway all they are at Tips & Techniques sub forum as I said before. Just read the writer of the original post and search for DarthFurby.
