no sound swf
mars714
no sound swf
Post by mars714 »
when i export to swf theres no sound, i run on mac 10.4.11 intel, download the file here:
http://mars714.deviantart.com/art/downl ... 2-82700236
if you want to help... thank you for reading
Rasheed
Post by Rasheed »
You probably need an additional MP3 file, next to your regular audio file (AIFF or WAVE). Anime Studio doesn't convert audio formats, so you need to it yourself, by supplying both formats in the same folder.
mars714
Post by mars714 »
Rasheed wrote:You probably need an additional MP3 file, next to your regular audio file (AIFF or WAVE). Anime Studio doesn't convert audio formats, so you need to it yourself, by supplying both formats in the same folder.
kay............................ i don't get it, i add sound track, wav, it won't let me select a mp3, what do you mean the same folder, what folder?
Have both sound files in the same folder as the AS file. You import the WAV into AS. When you export to SWF Anime Studio will use the MP3 automatically for the SWF export. You don't import the MP3.
mars714
Post by mars714 »
heyvern wrote:Have both sound files in the same folder as the AS file. You import the WAV into AS. When you export to SWF Anime Studio will use the MP3 automatically for the SWF export. You don't import the MP3.
i did that it doesn't work
mars714
Post by mars714 »
oh and now it's crashing when exporting...
http://mars714.deviantart.com/art/downl ... 3-82715269
is were you can find the full file.
Rasheed
Post by Rasheed »
There was something wrong with the MP3 file. I converted the WAVE file myself into MP3 (44.1 Khz, 128 kbps, stereo), and it didn't crash. Here is the result:
http://img411.imageshack.us/my.php?image=stufffgk7.swf
mars714
Post by mars714 »
kay, thanks!
Rasheed
Post by Rasheed »
If I may ask, what did you use to convert the wav into an mp3?
I used Audacity 1.3.3-beta.
mars714
Post by mars714 »
uh, i just clicked it and changed .wav to .mp3 ....
Rasheed
Post by Rasheed »
That obviously is no good. You need to convert it, not just rename it.
Download Audacity at
http://audacity.sourceforge.net/
Download the 1.3.3-beta version. It is very stable and has a good noise reduction. And it's free. Your audio levels are too low, so you will need an audio editor anyway. For MP3 you will get good results if you use a maximum of -0.3 dB as an audio level. If you use 0 dB (maximum), the MP3 encoder has troubles encoding.
If you have problems with Audacity, just ask in this forum, because many animators use it.
mars714
Post by mars714 »
i used that for the audio, and the flash behaves strangely, it is normal in one flash player, but has all kinds of beeps and strange audio in a different player, what should i do?
Rasheed
Post by Rasheed »
The only thing that is important is that is sounds fine in your web browser, embedded in an html file. I think only a few people play SWFs in stand-alone players.
mars714
Post by mars714 »
it is the web browser player that is acting strange...
Rasheed
Post by Rasheed »
The sample rate of your audio should be a multiple of 11.025 Khz (11.025, 22.05 or 44.1), otherwise the Flash plug in will do it for you and speed the sound up. This means you should record your audio at 44.1 Khz, or resample it as such.
