.mov exports don't fit in iMovie
Kratos
Post by Kratos »
Hello, dear Animators :-)
I'm new in AS and I've studied the tutorials. I made a short animation and I exported it as a .mov file on my desktop (MacBook Pro). Now I wish to import this short work into iMovie, but it fails. After a helpless search in Google I found your forum (Thank you, ancient gods!)
Does someone know how I have to proceed to make a movie out of AS-animations in iMovie? How do I change the .mov-code, so I can use the animation in iMovie?
Thanks for the help and sorry for my bad english.
Kratos
Have a look at the dimensions of your output. They are the same as your project settings. Do a test with the PAL preset and export this, it should import into iMovie without problems. If that fails, you have a problem with your iMovie installation.
Also if you don't use any compression, the file may be too large and iMovie may choke on it.
Kratos
Thanks...
Post by Kratos »
Thanks a lot for your answers, pals. I will see to it...
Kratos
