Switch laver problem
Ladytooner
Post by Ladytooner »
I am learning to use switch layers in regular Anime Studio. I can create the layers fine but when I try to connect the switch layers to a bone, only one layer shows up on the render block and in the animation check. What am I doing wrong? What should I do?
mkelley
Post by mkelley »
Not quite sure what your question is -- in a switch layer only one layer can show at a time. You change layers by putting the appropriate keys on the timeline.
