Stroke reset/restore?
bioroid
Post by bioroid »
After a line/shape is drawn and the line width is messed with beyond recognition, is there a way to reset the stroke to its original settings (like it was drawn with or whatever the freehand settings are)?
super8mm
Post by super8mm »
Select lines or part of a line you want then go to:
Top menu>Draw>Reset Line Width
bioroid
Post by bioroid »
While it does "reset" the line width, it doesn't use the values from the Freehand Options such as line width and taper values, which is what I'm looking for.
