Keyframe Rotation Problem? Please Help
betamax
Post by betamax »
I was getting excited about working with AS today and then this. I'm making a very simple keyframe animation with a an object rotating, but when i playback it rotates but also scales. Does anybody know why it's scaling? I never set any of the keyframe for scaling and never even clik on the scaling tool.
Here's a link to YouTube with a video screen capture of the problem.
http://www.youtube.com/watch?v=Zv8YLiXfpYo
Why is this scaling? It's just suppose to rotate.
Please help and thanks for your time.
betamax.
neeters_guy
Post by neeters_guy »
Point motion is translational. When you use the rotate tool on points, you are simply translating the points in a rotational manner; AS will still interpolate, or "tween", between the first and last keyframe in a straight line.
To get the effect you want, create more keyframes between the first and last keyframe. Or, even easier, rotate the layer, not the points.
betamax
Post by betamax »
neeters_guy thanks, I get it now, I think. Anyways I tried was you said and it work.
thanks again.
betamax.
DK
Post by DK »
You can also put the object on a seperate layer and use the Layer rotation tool. Layer rotation does not scale.You can adjust the pivot point of the layer with the Set Origin tool.
Cheers
D.K
