How do I assign a switch layer .....
Okse
Post by Okse »
....to a bone, I know it can be done I've seen it. But every time I have a go it messes up.
If anyone could help me I'd really appreciate it.
My names Okse by the way and ths is my first ever post, so "hello" and all that :)
patricia3d
Post by patricia3d »
Open the startup file
In Layer Window
Goto Frame 1 and ( Select Mouth with RMB ) , you will get submenu to select,
Goto Frame 10 and Select Mouth with RMB ) you will get submenu to select 2nd Mouth
Goto Frame 20 ..
Okse
Post by Okse »
thank you, I know how to assign keyframes by switching, but I need to no how to assign a switch layer/object to a bone.
b15fliptop
Post by b15fliptop »
You've got it the other way around. Switch layers are also bone layers, so you create the bone on the switch layer.
Stan
Post by Stan »
To assign a layer to the bone:
1. Make sure frame zero is active
2. Activate the Bind Layer tool
3. Activate a layer inside the bone layer
4. Click on the bone that you want your layer to be assigned to
