DELETED
There's a visibility icon on the timeline (kinda hard to see, but it looks like an eye). This toggles visibility, so if the character/prop whatever is visible, this will make it invisible, and vice versa. When invisibilty is 'on', the timeline background turns pink.
Hmm, I'm not sure I understand your question. If it's using switch layers you need info on then maybe download my tutorial from here which explains how to animate using switch layers...
http://blog.smithmicro.com/cgi-bin/bblo ... o_tutorial
If you are using debut u need to click on the layer and click on layer settings or just double click on the layer and you will see a checked box named visible. After that you will be able to adjust the invisible from the time line.
