When I try and export the Tutorial 4.4 Final in the Users Manual as a flash animation I should get a headless horse with a texture pattern. However, I get the headless horse without the texture pattern. When I export the same file as a QuickTime Movie I get the headless horse with the texture pattern.
My question is WHY? I should get the texture pattern in the flash .swf file as well. Has anyone run into this? I like this feature and would like the texture pattern to show up in the flash file. If anyone could shed some light on this, it would be great.
ASP 8- Flash Export
- funksmaname
- funksmaname
that won't be a vector swf - what you're doing there is converting a quicktime mov to a flash flv for flash streaming... if you dont need it to be an actual flash swf (so you can add interaction and have it remain vector) then this is the best way to go as it gives you complete access to effects including those from afterFX (motion blur etc)
