GIF rendering bug ?
Lychee
GIF rendering bug ?
Post by Lychee »
I have a problem with rendering GIF images.
I have an animation of shapes with simple colors (white with black outlines on original background).
But when I make a rendering and whatever GIF option I choose, I don't have my white color that is replaced by the background color.
Before it didn't do this to me, is this a bug?
I specify that I am on Moho 12.3 on PC.
1.Original Colors:
GIF animation render:
Best regards.
Re: GIF rendering bug ?
Try rendering a frame and clicking "Sample GIF Colors" before exporting.
IF that doesn't work, maybe this tutorial can help you:
Lychee
Post by Lychee »
I had done exactly as your tutorial shows, but it refuses to work properly.
I made a sample of colors on vector shapes for 4 colors but in rendering the program ignores the white.
Maybe this bug is due to my machine or the file itself, but could someone make a render of it for me to be fixed. Thanks in advance.
So here is the file: https://www.dropbox.com/s/wlla71ia4pmag ... .moho?dl=0
Lost Marble
Post by Lost Marble »
Víctor, I think you need to update the "location" in your user profile...
That is weird. I'm not close to the computer now, but will check the file later.
Lost Marble wrote:Víctor, I think you need to update the "location" in your user profile...
Oh, thanks, Mike, I just updated it. I'm officially in Ireland now :)
Ok, I checked it. Moho is not considering the white color right now. I don't totally understand the reason, but maybe it's too similar to the background color,
Anyway,if you make the white square twice as bigger as its now and then sample the colors, it will work fine.
Also, it works better with the dithering option disabled.
chucky
Post by chucky »
Víctor Paredes wrote:That is weird. I'm not close to the computer now, but will check the file later.
Kilkenny by any chance? Well then, top of the morning Victor! :D
chucky wrote: Kilkenny by any chance? Well then, top of the morning Victor! :D
Yes, I moved a month ago and have been working in Cartoon Saloon :)
chucky
Post by chucky »
at's excellent Victor, you must be happy to be amongst other pro Mohos, congrats !
I hope their Spanish is as good as your English!
Lychee
Post by Lychee »
Víctor Paredes wrote:Ok, I checked it. Moho is not considering the white color right now. I don't totally understand the reason, but maybe it's too similar to the background color,
Thanks for the tip Victor, visibly it was a problem peculiar to my file.
But it's a pity not to know the real cause of this bug.
Okay, then everyone is in the off topic, it's my turn.
WHAT??? VICTOR + CARTOON SALOON???
Disney can tremble!!! :lol:
art boutique
Post by art boutique »
GIF format did not support alpha transparency, therefore replace transparent background in your file by white color
chucky
Post by chucky »
Never fear, you have to select transparency in the gif options....
:idea: Look again , there are lots of options, amount of colours, dithering, transparency. :D
art boutique
chucky wrote:Never fear, you have to select transparency in the gif options....
You rights, my knowledge in this topic a bit outdated :oops:, edit: Gif not support semitransparency
chucky
Post by chucky »
I don't think 'any' gifs do , Art boutique, it's a limitation of the format , not Moho.
You might have to think of another delivery format.
