layers disapear in group
wr3yth
Post by wr3yth »
hi guys
i'm trying to add these layers to a group : Image
but when i do, they disapear : Image
I
wr3yth
Re: layers disapear in group
Post by wr3yth »
all those layers are in a bone layer
I
check the position of the new "eyes" group layer?
have you bound any layers to bones?
are these layers from a .psd or individual image files?
it also looks as though the original eyes layer has a "group" property -- there's an inverted triangle showing in your first screen grab?? and then again in eyeballs in the second grab???
wr3yth
Post by wr3yth »
every layers are bound to bones.
they are all individual images.
i don't think that inverted triangle has anything to do with group property, it opens this menu: Image
I
ok…
my best guesses are: (new) eyes group position; bone binding conflicts
could you upload the .moho (without the images)?
hayasidist wrote:it also looks as though the original eyes layer has a "group" property -- there's an inverted triangle showing in your first screen grab?? and then again in eyeballs in the second grab???
That's just the Quick Settings column showing for the primary selected layer. Confused me too at first. I always use the context menu for that.
synthsin75 wrote:That's just the Quick Settings column showing for the primary selected layer. Confused me too at first. I always use the context menu for that.
yeah - I never use the Quick Settings column either -- (stifles the sigh about the layer window layout...)
Yeah, I always keep that column hidden. IMO, I'd rather give the extra space to the layer name, and the QS panel is just a right-click away anyway.
Still hoping Copy/Paste Layers gets added to the contextual menu. (Ok, my turn to sigh about Layers Window.) :)
wr3yth
Post by wr3yth »
i made another file and accidently deleted broken file!
but i have same problem with this character: https://ufile.io/81my1
and it's even worse!
when i create new vector inside the character, i can't add points to it
I
That file works fine here.
I also have no problems working with that file. However I do notice that you've moved camera (track and zoom) and the pinkman group (scale, position, rotation) on frame 0
Take a look at your Preferences / Layers/objects and if "Auto Center New Layers" is checked this might explain your problems with the first file.
Also in Preferences / Tools - is "Enable drawing tools only on frame 0" checked? Are you trying to add points when not on frame 0???
wr3yth
Post by wr3yth »
i unchecked "auto center new layers" and problem solved.
thank you guys :)
I
