Mitered corners v14.5.1
With the new liquid shape clipping, in v14.5.1... and my create shape tool... we finally have a good mitered corner option. We can only do either mitered inner or outer corners, but it's better than nothing.
Mitered outer corners:
Steps:
1. Create fill-only shape.
2. Create fill & stroke shape on same vectors, using syn_create_shape.
3. Select the top, second shape.
4. Set liquid shape to Clip with the select shape tool.
Mitered inner corners:
Steps:
1. Create fill & stroke shape.
2. Create fill-only shape on same vectors, using syn_create_shape.
3. Done, no need for liquid shape.
These can technically be created without syn_create_shape. You just have to select at least two extra points when creating the second shape. The extra points can then be deleted.
