Fade in ?
amir91_5
Fade in ?
Post by amir91_5 »
Hi ..,
How Do I work ( Fade in & Fade out) in anime studio
merci
JCook
Post by JCook »
You can animate a layer's alpha setting (opacity) from 0 top 100% to fade in, and from 100% to 0 to fade out. Or you could fade to and from a totally black layer to fade in or out the same way.
Jack
amir91_5
Post by amir91_5 »
Where its (alpha)??
Read the built-in Anime Studio Users Manual, section User Interface->Layers Window and search for Layer Settings. There you'll find the "Opacity" parameter of the layer (commonly known as "alpha" for raster image files). Its default value is 100% (opaque) and can be set to 0% (fully transparent)
Here is a link to the online version of the help of an older version of Anime Studio called "Moho".
http://www.lostmarble.com/moho/manual/i ... erwnd.html
Reading the built in Users Manual is a good and worthly task to fully understand AS's features.
amir91_5
Post by amir91_5 »
This is an example of what I mean
http://www.e-frontier.com/article/artic ... 164/1/811/
At the beginning of the film in the Sky
thnx
