Moderators: Víctor Paredes , Belgarath , slowtiger
Rappybas
Posts: 18 Joined: Thu Jan 24, 2008 12:37 pm
Post
by Rappybas » Thu Jan 24, 2008 12:39 pm
I have a question.
How do I connect a layer to a bone?
I tried to put the layer in the bone 'map' in the right under corner.
but when I rotated or moved the bone, nothing happend :S
How can I do this?
Or is there any tutorial?
fiziwig
Posts: 197 Joined: Thu Jan 03, 2008 11:00 pm
Post
by fiziwig » Thu Jan 24, 2008 12:56 pm
Select the vector layer you want to bind in the layer window. Cick on the Bind To Layer tool in the tool window. Click that tool on the bone you want to bind that layer to.
--gary
Rappybas
Post
by Rappybas » Thu Jan 24, 2008 1:21 pm
Thanks, It works.
But it only works when I press Z to 'manipulate' the layers.
Not when I just rotate the bones :S
fiziwig
Post
by fiziwig » Thu Jan 24, 2008 1:49 pm
Rotate Bones in frame 0 rotates the bones independent of anything they are bound to so you can reposition them relative to the vector layers.
To have Rotate Bones also move the bound layers, you must be in any frame other than frame 0.
--gary
Rappybas
Post
by Rappybas » Thu Jan 24, 2008 2:00 pm
Ok Thanks!
So frame 0 is actually the set-up frame, wich won't be viewed in the animation?
fiziwig
Post
by fiziwig » Thu Jan 24, 2008 3:42 pm
That is correct. Animation starts with frame 1.
--gary
